strange panel print problem
I have a very strange panel printing problem. Each time when I am trying to print my vi's front panel, the printout always has some lines or characters missing. I have tried manually and programmatically, it just not working. Who can tell me the reason? What should I do to make sure the printout is complete?
I have set to print the entire panel. I used panel to printer method to print the vi.
thanks
Message 1 of 9
(5,485 Views)
Are you seeing indicators and/or controls that are blank or possibly you only see a small bit of the characters?  If so this can be caused by your font size selection.  Try increasing the size of the text window.  If that doesn't help try also increasing the font size a little.
Jim
LV 2020
Message 2 of 9
(5,483 Views)
thank you, but it still does not work. I ticked [scale the panel to fit], otherwise there will be a few pages to be printed.
On the panel there are a few clusters ,one table, and one graph. If one cluser includes three lines of numeric controls, when it was printed, only part of the cluster is shown on the paper. the unprinted area is white.
this problem has annoyed me for quite long time, please offer me some good ideas.
thanks
Message 3 of 9
(5,473 Views)
A good start would be to post your code.  If you can't do that, how about a screenshot with annotation as to what is not printing properly.  The code itself would be best.
Jim
LV 2020
Message 4 of 9
(5,470 Views)
The report to print is attached, when you manually print the front panel, it has some contents missing. You can see that by preview or print it to a document. I set scale panel to fit.
Message 5 of 9
(5,455 Views)
Sorry, I only go as high as LV8.0. Smiley Sad Hopefully someone else will be able to help you out.
Jim
LV 2020
Message 6 of 9
(5,445 Views)
Here is the vi in LV 8.0
Not looked at it myself yet
_____________________________
- Cheers, Ed
Message 7 of 9
(5,442 Views)
The only thing that I see messed up is your plot legend.  With the legend collapsed to the left, the legend text was doing wierd stuff.  When I opened it back out it looked fine.  Printed well too.  SorrySmiley Sad
Jim
LV 2020
Message 8 of 9
(5,438 Views)
Hi UniSA,
Can you describe what is missing? I don't see anything missing in the preview or the printed version.
Sappster
Message 9 of 9
(5,406 Views)
