strength of formula.vi
Would it be more expensive to use the formula vi in the Mathematics section rather than just wire up the formula manually and put it in a subvi?
In other words, does using the formula vi in place of wiring up the equation in a subvi slow the application down?
(2,984 Views)
If you are worried about performance, you should do both alternatives and then benchmark. 🙂
Are you talking about the formula node or the tools that parse formula strings? Parsing a formula string will always be much more expensive, but it has the advantage that you can change the formula at runtime from the UI.
What are you trying to calculate?
(2,975 Views)
Probably have to test that one yourself...
by formula vi, do you mean formula node?
and by "wire up the formula manually" mean using the '+ x / ' vi's from the numeric pallete?
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,971 Views)
it's actually formula.vi, not the formula node. I was only trying to plug in the distance formula (which is nothing for either approach). It just made me curious that if I had a much more invovled set of computations, which approach would be better? Would it be worth my time to wire up a subvi, or would it just be faster and more efficient to use this formula doo-dad.
(2,952 Views)
By no means I am a LabVIEW expert but since you will be entering your formula as a string (from the keyboard) and since the formula VI will be needing to parse it, I would think that simply wiring the formula (and making it a subVI) would generate direct code, be faster and take up less space.
Please correct me if I am wrong.
Berk
Instrument Drivers / IVI
(2,947 Views)
That's what I figured, too; I just wasn't sure exactly why it would be slower. Thanks for everybody's input; it really helps!
(2,941 Views)
