(string array indexing)
Happy New Year Shaun! I wish you all the best for this year. I am intrigued. Where are you? I don't think you have said so far.
OK have to admit I am not sure what you want. To help me understand could you please create two table controls (Table1 and Table2) filled with data and an indicator table (Table3) with the expected results. It must demonstrate how Row Match 2.vi doesn't work. If you could also tell me what data in Table3 relates to either Table1 or Table2. Remember to use Make Current Value Default on all tables before you save and post your example VI.
cheers
David
Message 31 of 36
(2,924 Views)
David,
Here's the vi that describes my requirement the way you wanted.
Thanks.
Shaun.
Message 32 of 36
(2,907 Views)
Here you go...
David
Message 33 of 36
(2,898 Views)
David,
I think we think
Message 34 of 36
(2,874 Views)
David,
I think we have a problem here.Smiley Sad. The code(matching row(DJC).vi) works fine for some cases but fails to operate as required for the two tables attached. Please take a look and suggest the changes necessary in code if any.
Shaun
Message 35 of 36
(2,874 Views)
The problem is that your datat is not equal!
The elements from table one have a CRLF appended to the first two columns, so the compare Aggregates return false.
Ton
My LabVIEW Ideas
Message 36 of 36
(2,870 Views)
