string byte parsing
i have 8 byte data(Hex string) for ex: 1A 2A 01 00 00 00 00 00 , how to break each byte in array of bits of array as each bit is representing a boolean value.
Message 1 of 8
(4,661 Views)
This way perhaps
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 8
(4,654 Views)
            This will help after i get a array of Hex string byte, i looking first how to convert a single Hex string byte in bits of array.
Message 3 of 8
(4,639 Views)
Do you want a 2-D array out of this where each byte is a row and each bit is a column?  Please clarify.
Message 4 of 8
(4,635 Views)
no i want 1D array
Message 5 of 8
(4,630 Views)
Sorry for the first mail i can try out with 2D array also.
Message 6 of 8
(4,628 Views)
I see you have a string with hex values, meaning the 2 char string FF=255, as an example. Try the "Hexadecimal String To Number" functions under the string palette. Then you use my function
Message 7 of 8
(4,626 Views)
Here is an alternate approach:
Ton
Message Edited by TonP on 12-05-2008 07:48 PM
My LabVIEW Ideas
Message 8 of 8
(4,616 Views)
