string constant array
Hi
I read data from Access  database (2D array), I need to use this data throughout my application. Is there a way to intialize
an array of string constants with this data i.e. obtain an string constant array with values from database
(4,907 Views)
I think you are looking for something similar to an Action Engine.
Norbert
Norbert
Expert: Geometry
(4,899 Views)
Accepted by topic author Nustian
No. A constant is a constant. You can:
1. Make a vi that accesses the information to a string indicator, which you'll then change to a constant and use in your program.
2. Access the information and store it in a shift register or send the wire to VI's in need.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,893 Views)
The data is read is just once and array is therefore need to be written to only when the application loads
(4,868 Views)
What exactly is the problem then? You've been told that you can store it in a shift register. Passing this to other parts of your VI is a pretty basic operation. Even if you had a block diagram constant, you would have to do the same thing. Since you are storing information in a database, presumably that information changes so a constant seems silly.
(4,861 Views)
I too say we need more information about what the poster wants.  But if you want to write some settings once, and have those settings available in the entire application, it sounds like a job for WORM.
(4,848 Views)
Thanks for the link as the information just needs to be read once this should do the job
(4,839 Views)
