string does not update in state machine
Help
I'm pulling my hair out over this one.
I have a string control I want to get the value this from the front panel at a certain point in a state machine type architecture, but the value held in the string by LabVIEW does not get updated during program run time for the purposes of the block diagram.
I have verified the VI is not corrupt by creating this simple VI to demonstrate what I am trying to do. (other case empty)
Neither the string length nor the indicator linked to the local variable, nor a probe on a wire connected to the string get updated if during the 2 secs after starting the VI something is typed in the string control.
LabVIEW version 2009
OS Windows 7
Could this be and OS related issue? - I normally use XP not Windows 7 with 2009 and I've never noticed this before.
Any fast feedback over the weekend would be greatly appreciated
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,560 Views)
What if you do it like in the attached snippet?
-Matti
(3,552 Views)
Accepted by topic author James_W
Try to set the string control to "update value while typing". (right-click...).
(3,543 Views)
