string from arduino comparison
I'm doing a project that involve labview+arduino Mega1280+xbee. and i have encountered a problem. i'm sending a string from arduino via xbee. labview gets the string and try to compare it with a constant string that i have chosen. but every time the comparison result is Fault . i have tried to send numbers : serial.println("1"),i have tried to send string: serial.println("detection red"), nothing works. I've placed a prob on the wire of the input string and it shows me the right data but the "equal?" is always fault. i would really appreciate if you could help me.
thanks a lot,        Ben
(3,289 Views)
Accepted by topic author BenHerut
This is a fairly common issue in serial communication.  You probably have non-printable characters in the string, such as a carriage return. Put an indicator (not a probe) on the return string, and set the string indicator's display mode to something like "\" codes. This will tell you if you have non-printable characters. If so, you need to either strip them before the comparison, or include them as part of the comparison string.
(3,285 Views)
Thank you very much, this issue has been bugging me for 2 weeks..
(3,277 Views)
