string indicator is not proplerly updating boolean action
Hello there,
in the below VI i am trying to send different CAN messages using boolean,
problem is if i want to send the different messages i am not receiving the response for the current sent message, instead i am receiving the response for previously sent message ,but if i press boolean for 3-4 times i am receiving the current update.
could anyone please guide me .
(2,345 Views)
I can't open your code, but the description is 99.7% a Race Condition.
Qestit Systems
Certified-LabVIEW-Developer
(2,313 Views)
The VI has dependencies that you didn't include so can't run it, and the problem might exist in those dependencies anyway.
But I will say that if your Boolean is False, then your loop is gonna run at a million miles an hour and it's gonna hog CPU resources.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,298 Views)
could you please check now and help me ..
(2,241 Views)
Hi Anil,
If you want to Execute True state on demand, you can better prefer Event based State Machine Architecture, In  that case all Local Variable and  Race Conditions can be avoided.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,230 Views)
please find the attached VI , still i am receiving the response for the previous message only.
please guide me i am not able to resolve .
thanks for your responses ...
(2,190 Views)
Please use Event based state machine architecture and shift register to hold string data.
(2,175 Views)
