string indicator scroll to bottom
This also works for me (on the right: property node of the string indicator).
Message 11 of 13
(2,831 Views)
This is a 6 1/2 year old thread.  And, although it may work, it seams rather strange to use string length to find a value larger than the vertical height of the string.
Message 12 of 13
(2,812 Views)
 I know, it's just that this could help somebody and it felt absurd to start a new thread?
@JÞB wrote:
[...]although it may work, it seams rather strange to use string length to find a value larger than the vertical height of the string.
 True, it dawned on me later that it's kind of the same as using just large number. If, however, the string indicator only displays one character per line, won't this method be "correct"?
Message 13 of 13
(2,787 Views)
