string or hex number split/divide in same number.
hello thanks,
I have to compare three decimal numbers(n1,n2,n3) separately with one number(N)outside of case. If it is less than the other number number then inside the 1st case the both number (N/n1)*constant number, then it will compare N with n2 outside and inside case (N-n1/n2-n1) at last inside the case (N-n3/constant-n3).
N= main number which will compare with three numbers separately
n1=1st number
n2= 2nd number
n3= third number
i tried something but its not working. image is attached
Message 11 of 27
(1,899 Views)
In short, if the comparison is true (N is less than n1, N is less than n2 or N is less than n3 ) the next condition should execute in the case structure.
Thank for inputs
Message 12 of 27
(1,884 Views)
Thank for inputs
Use "built array" of the thee elements in order [n1,n2,n3] and compare it with N. Use "or array elements" to get the condition.
Message 13 of 27
(1,866 Views)
showing error to compare with built array. image is attached. 2nd image is which im trying what crassrulzzzz suggested. am i doing right?
Message 14 of 27
(1,855 Views)
N and all other numbers should be scalar. Why are they arrays?
(Please attach your VI, truncated images are not useful)
Message 15 of 27
(1,838 Views)
hi,
i tried it  but getting wrong value now. also running out if ideas so did not designed condition 4 in here in VI.
N is main number here so.  so i want to do is.
If N<n1 = condition 1
elseif
N<n2 = condition 2
elseif
N<n3= condition 3
else
condition 4
stop
Message 16 of 27
(1,838 Views)
hi,
elseif
N<n2 = condition 2
elseif
N<n3= condition 3
else
condition 4
stop
So, if we start with Altebachs example and replace Or Array elements with Boolean Array to Number we can drive the case off the integer.  Case "4..." will execute anytime N>=n1.  Case "2, 3" will execute when N<n1 and N>=n2 Case "1" executes N>=n3 only and Case 0,default executes if N < all Array elements.  This is an Exact implementation of the if than else you wrote.  If different things need to happen when N> any two Array elements you may need to define all 8 cases.
Message 17 of 27
(1,823 Views)
i will try with this vi. and i will get back to you
Message 18 of 27
(1,813 Views)
its showing the same error can you show me example ? Im just lost 😞
Message 19 of 27
(1,807 Views)
Th
is is what was described
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 20 of 27
(1,794 Views)
