string random generation for length 3
Dear Sir,
How can i generate random generation of alphabets of length 3 in labview?
ex:adg,beg etc
Thanks in Advance
Sai Chitra.
(9,896 Views)
Hi chitrar,
Here is a way for caps only:
1) Use decimal to ASCII numbers for your letters
2) Generate a random number from 0-25
3) Add the result to the first letter (A) position which is 65
4) Repeat 3 times
5) Convert to U8 and then use Byte Array to String to get your string
Note if you want lower case also, change the 25 to 51 and then add 7 if the random number result is greater than 25.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(9,888 Views)
Homework?
(9,865 Views)
Picture the ASCII table as lookup table.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(9,859 Views)
