string to array
In the attached VI, I would like to know how to split up the data and plot different graphs as the times change (4 graphs in total for time = 20, 30, 40, 50).  Can you assist me in this endevour?
hiNi.
(3,350 Views)
I managed to simplify your code some to get one large plot.  Is there a reason the "Time: " is there when the header already tells us what it is?  Same for the Temp.  I would say that is a problem with the writing routine.  I'll have to think a little bit more on what would be the best way to get the times out.
(3,329 Views)
THANKS for your response and help!  I placed that header info myself manually in the text file as I wanted to make sure that the data from the instrument was going to the right column.  You can ignore the first entry. Sorry for adding extra work.
Sincerely,
hiNi.
(3,319 Views)
Accepted by topic author hiNI
Ok, what I did was turn the text into a 2D array of strings, index off each column, and formated as needed.  I didn't get so far as to get the times separated yet.  I'll leave that for you to do.
(3,284 Views)
THANK YOU!
(3,259 Views)
