string to array
The input string is abc = 4,def = 5. I would like to have string array of output with elements abc and def. Deleting the number including the equal to sign.. For this I used spread sheet string to array and the format used %[^=d*]. Any suggestions?
(3,072 Views)
Accepted by topic author nik35324
Hi nik35324,
You are so close to the result.
Just remove 'd' from the format string %[^=d*] and use %[^=*]
This will solve your problem.
HTML tutorial  HTML tutorial
162+ CLDs & 10 CLAs Trained
LabVIEW Training resources
(3,055 Views)
Got it. Used the format from Matlab and I completely forgot that this is LabVIEW  Smiley Happy
(3,047 Views)
