string to binary
Hello
             I have a string 000F45FF i want to convert into binary , how to do that
             result : 11110100010111111111
Message 1 of 8
(4,533 Views)
I would have a look at the 'Hexadecimal Sting to Number' VI or 'Scan from string' VI...  binary display can be set through right clicking on the indicator, Display Format, Binary.
Message Edited by BlueTwo on 01-27-2009 10:16 AM
Message 2 of 8
(4,528 Views)
That may not work if the string goes beyond a 64-bit integer. To OP: Are the ones and zeros supposed to be the characters "1" and "0", or something else? Any reason you're dropping the zeros at the beginning? Does the string have a maximum length, or any length?
Also, does the input string consist of the characters "F", "4", etc., or are you displaying the string in hex mode?
Message Edited by smercurio_fc on 01-27-2009 10:16 AM
Message 3 of 8
(4,519 Views)
Hello
           0 and 1,s are not character actually in my application i am getting the data from controller if 0 that channel is off and 1 is On. So i have total of 20 channels depends on data i can show which bit is on and off
Message 4 of 8
(4,511 Views)
You might like to convert the number to a boolean array, then you could have individual indicators showing if the channel was on or off.
Message 5 of 8
(4,508 Views)
if a convert the string to number and then number to boolean array i am not getting the result. Can u put it is a small ex.
Message 6 of 8
(4,506 Views)
here an ex , but i don't know if it's the best method
wow !!!so much posts , yes you have to take care if you need more than 32bit resolution !
Message Edité par tinnitus le 01-27-2009 10:46 AM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 7 of 8
(4,497 Views)
i forgot FP
Message 8 of 8
(4,483 Views)
