string to byte
ive got a hex-string like 88F4. with the "String To byte Array" the result is 56567052.
How can I convert my hex string in a byte array with 2 Numbers (88 and F4)?
(3,285 Views)
pass the string at first trough the from shexadezimal string functions
and th eresult trough the Quotient & Remainder of dezimal function and
build an array of the two result values.
Niko
> result is 56567052.
> F4)?
(3,285 Views)
String to byte array acts like a typecast and is not what you need if the string shows "88F4" when set to normal, not hex display. You need to scan values. A simple example is attached that works if your string is clean (even number of valid hex characters). There are probably better ways to do this.
(3,285 Views)
thanks for this example. its the solution of my problem.
(3,285 Views)
