string to number
Hello sir,
              i need to increment  string for using as an filename.   000 to 001...... n so on
Please help me to do so..
Regards
Tiju Thomas
Message 1 of 11
(5,679 Views)
Hi TIJU,
you can use the function "format into string". see the attached example. Hope it helps.
Mike
Message 2 of 11
(5,675 Views)
Hi tiju,
where exactly is your problem?
For incrementation you find a "+1" function in the mathematics palette. For string to number conversion you can use "Scan from string" or several format specific functions from the string palette... To get the filename you can use the "strip path" function from the files palette!
Message 3 of 11
(5,673 Views)
Hi!
   I'd suggest:
graziano
Message Edited by Graziano on 03-28-2008 05:16 AM
Message 4 of 11
(5,666 Views)
Hello Mr Graziano..
   This is want i looked for..thanks for ur help..revert back to u for help if i need..
Thank u once again..
TIJU
Regards
Tiju Thomas
Message 5 of 11
(5,652 Views)
Hi Graziano,
you can delete the "concat string" when you use a format string of "file%03d.ext"...
Or even better: use a format string of "%s%03d.%s" and wire filename (before number) and extension to the additional inputsSmiley Wink
And when there is only one number in the filename (or it is separated by other chars than 0-9) you can use a "split string" function with just the offset, the conversion to number will stop at non-decimal characters. You may use a "scan from string" with format "%d" and wired offset instead.
Message Edited by GerdW on 03-28-2008 11:39 AM
Message 6 of 11
(5,651 Views)
Thank you      Mike..
Thank you   GerdW
Regards
Tiju Thomas
Message 7 of 11
(5,644 Views)
Yeah i needed only that number string to increment ,so i removed other stuffs in concatnate string.
Ok i'll better do that way..i need auto formating the string ie..
 if starts with  0..  1....2     incrementing....
                      00 ...01..02...
                      000...001...002..
  like this..
Regards
Tiju Thomas
Message 8 of 11
(5,642 Views)
Hi TIJU,
to be more flexible you can use something like this.
Mike
Message Edited by MikeS81 on 03-28-2008 11:59 AM
Message 9 of 11
(5,638 Views)
@GerdW wrote:
Hi Graziano,
Hi GerdW!
   thanks, I learned something!!!!!
   Due to memory leaks (i.e. my brains always stills useful informations, or I have a brain-integrated excellent garbage collector which runs at realtime priority Smiley Happy ), I never remember format string stuffs!  One day I'm going to write a paper with examples on format strings (many things are not well documented, imho), and I'll put this!
graziano
Message 10 of 11
(5,631 Views)
