string to path
hello,
if string is like this
"c:\abc /user:deniss" result is "c:\abc /user:deniss" . All is Ok.
but if like this
"\\rain\ password /user:deniss" result is \\rain\ password /user\deniss"
colon is changed to "\"
Its no good.
And question this is a bug or feature? 🙂
LV 6.02
W2K pro SP3.
ps. of course i can first map disk with "net use..."
and then connect to disk with "no problema" 🙂
Deniss Karai
(3,601 Views)
Hi Deniss
You are right, that is messy. I imagine it has something to do with the special "\" character. Normally, e.g. in C, you use this character to select a special sign. So the structure like "\\" will mean to the system that the second "\" is a special character not a text.
I have played a littel with this and see some more:
\ \rain\ password /user:deniss
is tranferred to:
D:\ \rain\ password /user:deniss
\\\\\\\\\\\\rain\ password /user:deniss
to
to
"\rain\ password /user:deniss"
\\rain\ password\fgdfg /user:deniss
to
It looks like the character "\" means a lot.
But I have found a soluition for you. Just put the incomming strin
g into a array and then use "Array of Strings to Path" instead of String to Path. That will give you the proper value. I enclose the file.
regards
Pawel
(3,601 Views)
An interesting problem with a good solution.
On reading the help for the String to Path function it said, "Converts a string, describing a path in the standard format for the current platform, to a path." I think the fact it says 'in the standard format for the current platform' means it tries to be a bit clever and converts strings which are not written completely right into a path, making certain assumptions which aren't always the case.
The array function is a good way to get around it.
Good work..
Kim
(3,601 Views)
