string
hello,
Looking for 2 advices about string and array of string , cluster or other
1) Is there a way to limit text zone to only the size on string command
ie : for the moment my text zone has  for exemple a size of 65 pt that allow to type number with this format nnnn.nnn
the problem is when user type nnn.nnnnnnnn  the he does see the begin anymore   more over i don't want text to shift on left ....
2)  is there a propoerty to set to allow the use of enter key or other key to make an array of anything to go to next line or is it my own
to code event like that ?   and if i use a multicol list ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,249 Views)
Please use a more descriptive title than "string". For all I know, you could have been talking about super-string theory.
As for your questions:
(1) This has been asked more times than I care to count. I'm not going to bother giving you the options. You're more than capable of performing a simple search to find the answers that have been provided.
(2) There is no property to do this for arrays. You have to program it yourself. You could use a multicolumn listbox for this.
(3,242 Views)
                                    _ _ _ _ _ _
yes or tanga theory             \    /
                                          \_/
1) yes but thing can evolve and there could have a property to do this
2) same with array,   do you mean i can code the same with multicol list or list box has property i didn't see ?
Regards
(3,228 Views)
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Fixed-length-string-datatype/idi-p/1033996
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Option-to-Limit-the-Number-of-Characters-in-a-String-C...
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/String-Input-Element-with-specified-length/idi-p/15533...
Sorry. Meant to say a table control.
(3,223 Views)
