string
Hi Everybody,
How can the word written on the picture in JPEG be displayed on a string indicator?
Thank you for your answers.
(2,820 Views)
Hi star,
you should read about text recognition (or OCR)...
(2,817 Views)
For Understanding basics of Extracting text From an Image using LabVIEW (NI VISION) Try to find examples Related to OCR in NI Example Finder,
To understand the example you should be able to understand on "how to create.abc File"?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,759 Views)
