strip chart style
Bonjour,
quelqu'un a-t-il une idée pour effectuer une modification du style d'affichage de la grille d'un graphe déroulant.
On peut modifier la couleur mais je ne vois pas la possibilité de modifier l'apparence (ligne continue, ligne pointillée ou autre).
Merci de votre aide
(4,521 Views)
Is this what you want?
est-ce ce que vous voulez?
(4,515 Views)
The OP wants to know if there is a way to modify the grid line, not the plot line.
Ben64
(4,497 Views)
Hello boy,
yes it's for the grid line not for the plot line
(4,471 Views)
I'm not that good with labview, but here is way to do it.You can manually add a lot of cursors, this is not a good way to do it, but its the only way I could figure out. Hopefully someone else knows a better way.
Good luck.
(4,455 Views)
I don't think you can change the grid lines style. You can post this idea to the LabVIEW Idea Exchange forum.
Ben64
(4,447 Views)
Hello Jacouille,
Indeed, there are unfortunatly no built-in options to change grid line style (except for the color).
If you are not afraid of getting your hands dirty, you can create a custom graph with an XControl. But that is obviously not a straightforward solution. It depends on your needs.
You can find some explanation there: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2jVCAQ&l=en-US
Cédric | NI Belgium
(4,415 Views)
