structure inside while should work only one time ?
I can see only a Numeric based CS inside the Bool based outer CS. Am I missing something, or did you mean something different by "Inside the true case is another case structure that should only be true"?
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 12
(825 Views)
Later it was asked "is it possible to do without incrementing (+1) ", and I took that as meaning that he is looking for a solution that does not require the use of a numeric. Thus I was providing an alternative solution to the original problem.
Message 12 of 12
(806 Views)
