sub VI path and names
Is there a way to find out the path information of the sub VI ?
Using VI server I could get Callee's name which gives me no path informationf or the SubVIs.
(2,807 Views)
At The VI menu, open: Browse -> Show VI Hierarchy.
At the opened Window: View -> Full VI Path In Label.
Then when you point at a SubVI, you will see the full path of it.
Hope it Helps...
(2,807 Views)
In addition to what Bush-Man suggests, you can also use the current VI's path.vi located in Functions>>All Functions>>File I/O>>File Constants in the subvi and create an indicator to see the path. You would need to run the subvi once to see the path though.
Ankita A.
(2,807 Views)
