sub vi in while loop does not stop while loop
Thank you for your help.
I have solved the problem.
This is what I saw - when the highlight execution was on, the sub vi showed running through an iteration.  The while loop did not.  For every input from the while loop into the sub vi, the sub vi ran three times.  I don't know why.
The solution was to re-write the sub vi, and insert the new one.  This sub-vi was from a previous project.  I have seen some problems with MS report generation VIs that do not operate if they are copied.
Thanks to everyone for trying to help, even with the insults.
metzler CLAD
Message 11 of 12
(754 Views)
What insults? None of the replies were insults.
Message 12 of 12
(731 Views)
