sub vi pop up
when the main VI is called, one of the sub VI also shows up.
how can I fix this?
Message 1 of 8
(4,378 Views)
oh so many senarios come to mind. Could you post your code?
Message 2 of 8
(4,373 Views)
here it is..
thanks,
Message 3 of 8
(4,372 Views)
I am in LabVIEW 8.0.1
This could present a problem in trying to help you as even the file I/O vis you are using were "updated" when I opened the main.
But, for clairification...
1. Which SubVI is opening?
2. Is it opening when you run the vi, or when you open the VI?
Message 4 of 8
(4,367 Views)
Do you remember in the last thread you started that I told you how to do some basic debugging and to set a subVI to pop-up when called? That's what you did and now you need to return to the previous settings.
Message 5 of 8
(4,355 Views)
the only subVI in the "load instrument settings" case
the subVI opens when I opens the top level VI
Message 6 of 8
(4,352 Views)
I can't reproduce the issue, however, My computer doens't have the DLL file that is used in one of your drivers. sorry, but I don't think I am going to be able to help... Anybody got LV 7?
Message 7 of 8
(4,346 Views)
thanks for your help...
I was able to fix it for myself...
I needed to modify 'subVI node setting...with the subVI..
also de-selected the 'suspend when called' in Operation menu...
Message 8 of 8
(4,341 Views)
