sub vi
I can not open a sub vi in a main vi.
I made the sub vi like it's explaned in the manual, but for some reason it will not open in a new vi.
Any sugestions?
(3,127 Views)
Could you post your mani an subVI, here?
(3,121 Views)
OED.vi is the main.
Buffer.vi The Sub
(3,093 Views)
I think we misunderstood each other. You created two separate VIs. None of them is a part of the other, and so none of them is a subVI to the other. To place one into another, either:
- drag and dropp the icon of the one onto the Block diagram of the other
- in the Block diagram: right-click > Select a VI... and select your VI
Could I help you?
(3,089 Views)
Hi Fluppebowl.
Yes, as ghighuphu is saying, you need to actually drag the VI you want to use as a subVI into your mainVI. In order to fully understand this concept, I encourage you to read this:
Tutorial: SubVIs
If you have any questions, please let us know.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(3,063 Views)
