subVI question
I'm developing a subVI which reads an input string, compares it with some strings (string1..) that I want to match and returns a numeric value with the following values:
-1 if string1 matched
-2 if string2 matched
I've tried to do this by calling the Match Pattern vi 4 times in parallel and then using 4 if structures, but when I try to wire the results from each of the ifs to the final return result I get some errors.
Please tell me how can I solve that or advise me on a better method for implementing this VI
(2,798 Views)
Create an array of all you strings as a diagram constant and then use "search array":
Message Edited by altenbach on 05-21-2008 11:36 PM
(2,789 Views)
Hi vici4u, and if your string only has to contain the strings your are searching for, then use a loop with the match pattern function.
Mike
Message Edited by MikeS81 on 05-22-2008 08:41 AM
(2,785 Views)
