[subpanel labview 8.0] Another problem of subpanel...
    My problem is quite common, I want to add to a main program a subpanel connection and when the execution inside this one is complete catch the output cluster I've done inside the subpanel... I've seen a solution on the forums (see here) to catch the value of a control, but it doesn't work !
    My subpanel program is as simplest as possible : It's just a global while loop which contains some control where the user is asked to enter some characteristics of an experiment. When the data are entered, He must press a "check data" button to verify the data entered... The SubVI is attached...
       Can somebody help me please...
       Thanks a lot !
          Pi-r
(2,466 Views)
You have already received the answer through the AE E-mail support but I'll post the answer here too.
The VI below shows how to exchange data between the subVI and the MainVI trough VI server.
The Error in your program was actually that you didn't uncheck the "Lock Front Panel" feature in the Event Case.
Regards.
JorisV
(2,448 Views)
