subset string array
Hi all,
I have a string array that contains Day0, Hour1, Week5, Day3, Year3, Day4, Hour0, Day5, Hour3, Day2, Week0, Week3... (these are randomly mixed).
Now, from this array, I want to create another array that ONLY contains the string 'Day' (Day0, Day1, Day2, ...).
I tried several things but it wasn't successful. The attached VI only provides the last 'Day' element.
Could anyone help? Thanks,
Yoon,
(3,249 Views)
Of course it provides only the last element. Each time you have a true case, you overwrite what any previous true case has created. You need to use a shift register with a build array in the true. This would be almost identical to the shipping example called Building Arrays. If you were to open the example finder, you would see this under Fundamentals>Arrays and Clusters.
(3,248 Views)
Thanks a million.
(3,240 Views)
