07-27-2018 12:35 PM
I'm probably not even close, but I learn the most out of getting corrected by the community here. Learning as I go!
How can I take a value from 1 channel and subtract that value from all other channels?
I'm not entirely sure what this code is doing, but it's definitely not doing what I want.
Index array may not be the right tool to use?
How can one index an element from an array and then put it back?
Solved! Go to Solution.
07-27-2018 01:29 PM - edited 07-27-2018 01:29 PM
Remember way back with your first post I told you arrays and FOR loops are your friends? Make your life easier.
07-30-2018 12:39 PM
@crossrulz
I do remember that, thanks.
07-30-2018 01:35 PM
Arrays and FOR loops really help reduce the amount of clutter
07-30-2018 03:13 PM
You seem to be serious about learning and improving your LabVIEW skills. Maybe this is a good time to obtain a copy of the LabVIEW Style Book by Peter Blume. It's rather old, but the concepts it teaches are absolutely still relevant (which is probably why it was never updated, and it's still pretty expensive).
This is considered to be the "LabVIEW Bible" by many, and if you use it at least as a base to develop your own style, you can't go wrong.
07-30-2018 03:55 PM
Bill,
Thanks, I'll check it out. I'm thinking of taking the LV core classes 1&2 and perhaps being certified someday
11-25-2021 08:42 AM
...did you ever get that certification🤞?
