subvi input and output
I create a Vi, and I want to start it in another Vi as a subVI. My problem is, that I don´t know how to create the inputs and outputs of the sub VI.
thanks for your help.
best regard,
Joaquin
(2,564 Views)
It's in the help index under "connector panes" and "assigning terminals"
You need to change the vi icon in the upper right to a connector, select the terminal pattern and then using the wiring tool, click on terminals and controls to get the assignments you want.
I was in your same situation just a few months ago. Learning LabView on your own isn't the most intuitive exercise.
(2,558 Views)
