subvi no show an array
hi!
i have create a big program, so i have done a subvi of it.
Now, i call this subvi from a new program...one out of this subvi is an array...so i create an indicator in this terminal out...
but when i simulate i can see nothing in my array, no information is receiving my array why?
but if i open the original program...the orginal array work good why??
thanks!
(3,863 Views)
I have attached simple program, which is calling SubVI generating an array and displaying on the main program front panel, may be this similar what you are looking for.
(3,858 Views)
sorry but i am usig labview 2009, i cant use it, can you change the format?
(3,855 Views)
Accepted by topic author alan4
Here you go for LabVIEW 2009.
(3,853 Views)
sorry but i don't know how to do it in my program..i attached you mi files if you can help me please...
thaks
(3,845 Views)
As i see in your code, you are using tcp/ip communication for streaming array to client. You should have a look on the examples from Help >>> 'Find Example' & search for tcp/ip,  look on the simple data server.vi and simple data client.vi.
(3,840 Views)
