subvi not able to find location
Also, in case you transfer a VI to a different machine you need to ensure that you include all subVIs.
For this you should select "Save As" >> "Duplicate hierarchy to new location"
If you are working on the same machine ignore this. Smiley Indifferent
Message 11 of 13
(550 Views)
yes .Am developing the program in one system and running the program in another ssytem.I used to copy from this system to the other one. This problem happens in both the systems. Now I am trying to sort this problem by arranging all the subvi into a library. Am learning how to do so.
Message 12 of 13
(536 Views)
xdaf wrote:
Other possible reason: In your PC there are 2 different sub-VIs with the same name, and when you open the main VI, the "wrong" one is already in memory.
I'm quite convinced you'll solve your problems just putting some order in your VI hierarchy.
Awesome.  In the dark old days when my team was trying to optimize code, we had several cases where the VIs were calling the same VI from different places.  It was madness to try to sort out all the heirarchy problems!  I believe this to be the problem also.  Kudos of course.
Bill
Bill
CLD
(Mid-Level minion.)
Message 13 of 13
(525 Views)
