subvi randomly not working
Hi Norbert,
thanks for all your effort, but the DLL I/O seems to not be included in the NI I/O Trace. It is done through "CallExternalLibraryNode", not a VISA. Not even a USB-traffic scanner would help me, I guess, because the data does not seem to "reach" the USB interface.
I feel the strong urge to throw not only the PC out of the window, but also light it on fire^^
Pedro
Message 11 of 26
(1,277 Views)
Pedro,
i think you would get lots of kudos for that video on youtube 😄
Well, obviously we have the following situation:
a) The DLL does not return an error to the calling code, in your case the wrapper VIs
b) The USB port does not send out anything
c) You have no tool available to make sure if the command was put on the output buffer of the USB port at all
d) Using other callers than LV seem to work quite stable
e) Testing different setups of the CLFN (UI thread/any thread) and timings did not change the behavior
This is indeed an aweful situation.
Just for brain storming:
- What about encapsulating the given code in a wrapper DLL (ANSI C)?
- What if the DLL gets unloaded after "Connect" and before "Write"? Could this result in such an issue? Does "Write" have any error information available if the connection is valid at all?
Norbert
Norbert
Expert: Geometry
Message 12 of 26
(1,271 Views)
Hi Norbert,
The DLL I'm using is already a wrapper of a C++ DLL, sorry if that didn't come out clearly. Or do you mean a wrapper for the wrapper?
header file excerpt from the write definition: Returns: Nonzero, if data has been successfully written to the device; otherwise zero. , so yeah, that's my return value.
What do you mean with the DLL getting unloaded?
Thanks heaps for your help so far!
Pedro
Message 13 of 26
(1,269 Views)
I hope GetVersionAnswer isn't updated in the sub vi's?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 26
(1,262 Views)
Hi Yamaeda,
I'm not quite sure as to what you mean with GetVersionAnswer being updated. Can you please explain this a little more in detail?
Pedro
Message 15 of 26
(1,254 Views)
You use the GetVersionAnswer in the loop, but if it's changed in some of the sub-vi's you'll get the wrong value.
/Y
Qestit Systems
Message 16 of 26
(1,251 Views)
Nope, that does not happen. Thanks for the input though. Any more suggestions?
Pedro
Message 17 of 26
(1,248 Views)
With visa i generally use a small wait between writing and reading, like 100ms, maybe you need it with the USB also?
/Y
Qestit Systems
Message 18 of 26
(1,237 Views)
Already tried waiting, that did not work out. Funny fact: whenever it didn't work, it won't work until I restart LabView and then not everytime as well. But if it worked, it worked until I shut down LabView again. Some memory allocation problems maybe?
The programmer of the DLL and the wrapper DLL will look into this problem this week as well, I'll keep you updated, in case someone else encounters a similar problem.
Pedro
Message 19 of 26
(1,236 Views)
It sounds alot like the problems i had with an ActiveX object. If the program got errors so the object wasn't closed properly it got stuck in memory and required a restart of LV to clear out.
/Y
Qestit Systems
Message 20 of 26
(1,233 Views)
