suggestions Regarding,controlling the 5# Pneumatic Valve using PCI-6221
Hi Everyone,
I need a suggestions if anyone worked on this similar kind of project,
We are Trying to control the Pneumatic Valve using Relay to trigger through PCI-6221
If any Reference code kindly share and support me on the same.
(2,609 Views)
It can be done, you will need some electric wiring to be done first.
1. The pneumatic value will need to be wired thru a relay - as a relay can actually switch and route the current to run the valve thru it. The TTL Digital out of the PCI card cannot actually power anything. It does output a TTL voltage, but it only as a digitial signal/flag and does not have any current to drive anything..other than maybe an LED.
2. You'd need a Relay that has to meet 2 requirments:
  A. Activated by 5 Volts DC - because that's what the PCI digital output voltage is.
  B. The Relay side, needs to handle DC or AC. Very likely your valve runs by 24VDC.
3. You need a VDC power supply to actually power the value -again as the PCI NI card cannot do this.
Google, DC Relay wiring...
Regards
Jack
(2,579 Views)
