sum window array
Hello everyone,
I need some help creating a sum window on an array. For example, Im trying to make a summing window of 5 elements moving throught an array of 10 elements.
The attached .vi only works for the first 5 elements and I need to move throught the 10 elements point by point.
Thanks for any help or suggestion.
(3,794 Views)
Accepted by topic author Alvaro_Ortiz
One thing that jumps out to me is you're never updating the index on Array Subsets.  You've wired a constant 0 to the input.  This, of course, means that every iteration of the loop gives you elements 0-4.  Try wiring the i terminal to the index inputs.
Tim Elsey
Certified LabVIEW Architect
(3,793 Views)
I'd add that you probably want to index the result of your summation so you get an array of sums of the selected length of elements.  No?
Jim
(3,776 Views)
Elset, you were right .. I just need to connect the index of the for loop to the array subset to update the values and that was all ... sometimes you just keep giving turns around on a simple solution ..
I am going to attach the solution if somebody have something different or see something wrong just let me know.
Thanks ..
(3,760 Views)
