sunny boy using labview
thanks for ur respose .......... Yes this kind of inverter makes alot of invertions ,,, but I will use it to invert the Dc power to Ac power
Message 11 of 22
(1,785 Views)
What model number?
Message 12 of 22
(1,778 Views)
SUNNYBOY3000TL/4000TL/5000TLwithReactivePower
Message 13 of 22
(1,770 Views)
Just I need to know which formula used to invert from dc to ac........... by using this formula I will be able to simulate this inverter by using any software ........ just I need the basic idea........... If u know the way to do this plz post me asap
Message 14 of 22
(1,767 Views)
There seems to be quite a few documents on the web site. The "Measured Values and Parameters" document goes into considerable detail on what parameters cna be set or measured.  At a quick glance it does not seem to provide any algorithms or equations to describe the behavior.  Considering the number of parameters available, a comprehensive model will likely be quite complex.
I suggest that you study those manuals and then contact the manufacturer to see if they will provide you with a model or guidance on creating your own.
Lynn
Message 15 of 22
(1,751 Views)
We're the ones who should be screaming since it took 12 posts to get even this small amount of information out of you.
Next time, help yourself by providing details for what you need to do. The web page I pointed you to is something you should definitely read.
Message 16 of 22
(1,746 Views)
What, you mean "I have a problem. Can you give me all the answers?" is not sufficient?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 17 of 22
(1,737 Views)
Thank u for everything ,, I will try to find out
Message 18 of 22
(1,708 Views)
U dont need to scream ............. once I hsve found out ,,, I will give u the answer
Message 19 of 22
(1,707 Views)
Now that's funny.
My anticipation is boundless.
Message 20 of 22
(1,697 Views)
