superpose graph
i would like to superpose graphs by node of property. I have an acquisition with 5 and soon 7 graphs and i want to have the possibility to put on the same graph (unrolling) 1 or all the graphs. But i don't see how to do. What could i use to put after the unassembling of the signal to can call by node the graphs. I join the vi to understand better.
(3,026 Views)
Salut,
Pour afficher plusieurs courbes sur le même graphe, il faut que tu utilises la fonction assembler des signaux.
ClémentG
(2,997 Views)
