support 64bit and 32 bit development
I have a client which wants 64 bit support with our labview application, other projects require 32 bit support.  What is involved is supporting development of both types of applications from a single pc and labview?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(5,060 Views)
Do you have a 64-bit OS? Do you have the 64-bit version of LabVIEW? You'll need the 64-bit version of LabVIEW. You can have both the 32-bit and 64-bit versions (LV 2009) installed on the same computer. If you're on Windows I would suggest starting with this article: Using National Instruments Products on 32-bit and 64-bit Windows.
(5,042 Views)
I am considering the move, I would get the 64bit OS (windows 7) and 64 bit labview and 64 bit PC, just seeing what issues I might have supporting 32 bit from this platform.
Paul Falkenstein
(5,019 Views)
Hello Paul,
smercurio is correct. You can have both versions of LabVIEW or their runtimes (32 bit and 64 bit) on a 64bit machine. Since the 64-bit and 32-bit application work with different dlls, they won't interfere with each other. The KnowledgeBase, LabVIEW 64-bit vs. 32-bit FAQ, goes into more detail about the differences between the two versions of LabVIEW.
JimS
Jim St
RF Product Support Engineer
(4,994 Views)
I am interested in the toolkits as well specifically Vision and DB for the current application.  Are there any known issues with the 64 bit version of Labview?
Paul Falkenstein
(4,979 Views)
Hello Paul,
The Vision Development Module 2009 is supported for Windows 7 and Vista 64bit. As for the DB toolkit, are you asking about the Database Connectivity Toolkit?This toolkit will work with a 64bit system. For a complete list of toolkits and modules for Windows 7 64-bit, please visit the following link: https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
JimS
Jim St
(4,964 Views)
Thanks.
Paul Falkenstein
(4,948 Views)
