swap element in array
I am trying to control a screw elevator with labview.  I have an array which holds the values for current lift position.  Once the lift is at a new position I need to overwrite the old position of the lift with the new value in the array.  I went through all the array commands and dont think anyone is going to work.  I am using labview 7.0
(3,915 Views)
Replace Array Subset should work. You can use it for single elements - one element is a subset of the array. Just feed it the index of the element you want to overwrite and the new value. You may also need to put the array into a shift register.
Lynn
(3,914 Views)
Thanks Honey that was a great help. Appreciate that.
(3,884 Views)
