swapping the crio controller from project explorer
I did a mistake and chose the wrong cRIO controller. Now I find I have different controller but my whole project is built with all modules and vis. Is there a way to simply edit the current controller to the right one!
Ta
(3,075 Views)
Accepted by topic author kwaris
Hi kwaris,
You can add a new controller to your project, and then just move the items from the wrong controller to the correct controller.
You can't move all components in one go, but you can move items in groups. This will make sure the project is rebuilt correctly.
For items you can't move, please try a copy and paste operation. This is the case for information such as build specifications.
Once everything is moved or copied, then you can delete the wrong controller.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(3,042 Views)
