switch on off
Hey
I am trying to create a sequence when I can switch on and off my peristaltic pump (via parallel port) by simply pressing a button. I inserted boolean button (from a template) however have no clue how to programme it further? Any ideas?
Thank you a lot!
(3,757 Views)
Hi Chebi,
instead of a sequence you should rather use a loop with an event structure inside…
Why do you need a button from a template? Are the ones available in the palettes not ok?
(3,753 Views)
Thank you for your help.
I have already changed it into the buttons found in the palletes. However, I am still a little bit confused how to make a fully functional loop.
Cheers
(3,734 Views)
Hi Chebi,
NI offers a lot of online resource to learn LabVIEW (see www.learnni.com ).
You don't need to stay confused… 😄
(3,709 Views)
