switching between arrays
Hi I have two arrays and I am trying to hook up a control that chooses one or the other, I am having issues doing this. Could someone lend some help?
 I have my block diagram and front panel attached.
(4,040 Views)
Accepted by topic author Adam_Keller
Try using SELECT FUNCTION.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,032 Views)
Yep, the Select function is exactly what you are looking for.  It is hiding in the Comparison palette.
(4,023 Views)
Perfect exactly what I was looking for!
Thanks for the quick replies!
(4,014 Views)
And if you have more than two arrays, use a case structure with N cases instead and hook it up to an enum, for example. 😄
(4,010 Views)
I would use Swap instead of Select in this case (I almost never use Select these days).  It is faster, especially for arrays and composite data types.  Added bonus: you can choose which output to use depending on the logic of the swap? input, often eliminating wire crossings or an added Not operation.
(3,989 Views)
