symbolic functions
i would like to know how to evaluate symbolic expression in labview
Message 1 of 8
(5,449 Views)
Can you be a bit clearer and more explanatory on what exactly you want to do... ?
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 8
(5,446 Views)
i want to divide for example (x^3+x+1)by (x^2+1) ,performing long division
Message 3 of 8
(5,443 Views)
Try the Mathscript node, if you have the PDS version of LV 8.5 or later.
Message Edited by parthabe on 05-06-2009 02:18 AM
Message 4 of 8
(5,441 Views)
Else, you can always use the primitives in the Numeric palette for simple calculations like these. Smiley Happy
Message 5 of 8
(5,436 Views)
This thread is related to this one... Just to get the background Smiley Wink
To my knowledge MathScript /Matlab is the best you can get for symbolic operations...
Message Edited by GerdW on 05-06-2009 10:47 AM
Message 6 of 8
(5,410 Views)
If you want to divide polynomials then why not use the "Divide Polynomials.vi"?  This will give the quotient and remainder polynomials.  I believe the CRC algorithms utilize the remainder of the polynomial division.  If you are interested in the algorithm, just open the subVIs.  The core division algorithm is implemented in G.  Attached a VI that implements your sample problem.
-Jim
Message 7 of 8
(5,387 Views)
LabVIEW doesn't really do symbolic math.
If you need that, you might want to look into the Maple Professional Toolbox for LabVIEW. (Sorry, I am not familiar with it).
Maybe there is also a way to use e.g. Maxima from within LabVIEW.
Message 8 of 8
(5,375 Views)
