sync encoder and load cell
I am building a load frame using a load cell and quadrature encoder. The encoder is reading the displacement of a .5" pitch lead screw. I am able to create a xy graph showing displacement and force applied to the load cell. I would like to use the encoder as the clock or count the pulse from the encoder and gather the data from the load cell at a predetermined position (i.e.. .1" of travel). Is there a way of taking the elements from an array at certain increments or would it be better to take the data after the encoder has sent a certain number of pulses.
I have attached the vi for clarification.
Equipment:
Labview 8.6
quadrature encoder 2500 ppr
PCI 6251
SC-2345
load cell Trancell BSA-200 connected to a SCC-SG24
Thanks in advance for any help or direction.
Henry G
(3,228 Views)
If the hardware supports it, I would clock the A/D conversions using the pulses from the encoder.
Ben
(3,226 Views)
Thanks Ben, I am fairly new to NI. Could you elaborate or point me to an example?
Thanks Henry
(3,214 Views)
Help Find Example...
Browse >>> Hardware Input and Output >>> DAQmx >>>Analog Measurements >>> Voltage >>> Acq&Graph Voltage -Ext Clk.vi
Looks like it may be a good starting point.
I encourage yo uto browse those examples for one that meets your needs.
I think there is one in that pile that shows how to sync to the digital I/O as well.
Ben
(3,205 Views)
