sync
I am trying to figure out what is the best option for doing the following:
1) Generate a potential signal (which starts a trigger). Currently doing with NI-6501.
2) Generate a potential and acquire a current. I am using a CHI600D potentiostat, throught the labview interface provided by the company (the code works through the call dll to access the functions).
I need to know what current corresponds with each trigger (sent with the NI-6501). So, first trigger signal I get x1 amps, second x2 amps, and so on.
For that, the signal is sent when I get a certain time multiple from the CHI. So I can trigger every 100ms (for example).
The problem: too slow. I am able to do this each 50ms (roughly). I need to do it every 1ms at least.
I am able to buy whatever hardware I need for doing this simple task. I know the problem is in the way I acquire data from the potentiostat, and recently I found a Keithley 6487 which none was using, and I was thinking of using it instead of the CHI, through a GPIB-USB-HC controller, but not sure. I can also buy another instrument, not a problem.
The question is: how can I sync the trigger with the intensity signal I get?
LabVIEW 2014 SP1 32bit
Win10
Thanks for your time. Any ideas are welcome.
Cheers,
Yan
(5,073 Views)
I have never done such task, but I think you should use the Keithley 6487. It comes with LabVIEW driver from Textronix. The given driver ( http://www.tek.com/specialty-instruments/6485-software/models-6485-6487-and-6514-ivi-visa-based-driv... ) .
This Keithley 6487 has a voltage source too and a picoAmp meter part. I think you can do all you want only using this Keithley device, check its driver, it has some LabVIEW examples (like triggering a measurement, etc...).
edit: and yep, buy this interface: https://www.ni.com/en-us/shop/model/gpib-usb-hs-.html
(5,055 Views)
Hi Blokk,
first of all thanks for replying.
To explain it a little bit better, I need to control two instruments at the same time. One is the Keithley, to apply apotential and record the intensity (easy). My question was more focused on how I can apply a potential (with the Keithley) while triggering the other instrument (trigger is just apply a TTL signal). The syncronization part is what is not clear to me.
Cheers,
Yan
(5,008 Views)
Most isntruments can accept an external trigger.  Is this a possibility?
Bill
CLD
(Mid-Level minion.)
(5,002 Views)
Very good point Billlko! Yes, just checked and has a trigger link. Just need to figure out how it works now, maybe this could be the easiest solution.
Cheers!
Yan
(4,997 Views)
Download the manual, and read it. It has the required info...
(4,982 Views)
Well Blokk, that is obvious...
(4,970 Views)
