Hello everybody,
we are students studying biology and have been working with Labview 8.2
for the last 2 month. Now, we have been assigned a more difficult task,
for which we would like to hear your advice. We apologize in advance
for our bad english.
We are going to acquirie analog data from 16 different channels, using
a pci-6143 card. In addition, we want to activate our external
stimulation device using a digital output 24bit 1D boolean array. This
action is supposed to happen after a certain amount of analog
measurements, e.g. 2000 time steps. To receive the most exact data, we
want to avoid LabViews clock functions and only use the clocks of the
PCI-Card
So, the question is: Is there a way to tell the PCI-Card to do
different things after a certain amount of time steps? Like saying: For
the first 2000 time steps, you send a 24 bit binary array containing
only FALSEs, in that particular step you send an array containing only
TRUEs and afterwards again only FALSEs.
The way we assume this could work is the following:
We create a CO-Pulse channel, use the "Get Terminal Name with Device
Prefix.vi" and use this as a source for our sample clock with which we
are going to get our analog samples. In addition, we create another
CO-Pulse channel with a specified delay and another "*Device Prefix.vi"
to use as a source for our second sample clock which is wired to our
digital output channel. This way, the time difference between the start
of the analog input and the digital output should exactly equal the set
delay.
Is this the correct way of solving this sort of problem with LabView, or can you recommend a better approach?
Thank you in advance
Stefanie and Tobias
