synchronize icons error
Installed LV 2010 (32bit).
Tried to synch icons and got this on two machines.
One is a Windows7 laptop.
The second is a fresh PXIe 8133 controller with an XP running on it.
Any ideas what is wrong?
Thank You,
Maciej
(2,758 Views)
This was also reported here, and I've seen it as well. I suggest you add a comment there, as that's the best place to access the developer.
I'm not sure, but I think that when I ran into this I ended up updating the file manually using a copy I had somewhere.
___________________
Try to take over the world!
(2,750 Views)
