synchronize sample rate
I am gathering data from two different vi and then add them together. But they are sampling at different sample rate. Is there any way I can add something to synchronize the sample rate after the output of each vi?
Thank you.
(2,570 Views)
You could synchronize the acquisitions so they are sampling at the same rate, or you could resample the data after the fact.
Best Regards,
John Passiak
(2,559 Views)
