syntax for on sampling board channels
What is the syntax of channel string to sample only the on board channel (ex channels 2 to 6) while using SCXI 1000 and SCXI 1100 modules. Will it be something like " ob!2:6!sc0!md0!0:0 " ?
(2,599 Views)
Dunty,
The syntax will probably be something like "ob0!sc1!md1!2:6".
Take a look at the following Knowledge Base article:
Valid SCXI Channel String Arrays under LabVIEW
http://digital.ni.com/public.nsf/websearch/6FC83B7AC9ACA5788625615B00823D65?OpenDocument
Justin Britten
(2,599 Views)
