system exec VI command line input
I am trying to evaluate a temperature sensor.To do that I have to monitor thermocouple readings.Thermocouple is connected to FP-TC-120 temperature module. Besides, I have to acquire data from an optical spectrum analyzer. I am using 3650.VI to monitor the temperature and 86140B Trace_Screen Capture (2).llb o trace the data from the OSA. I want to combine these two VIs and automate the process. I tried to use "invoke node" to call the VI that traces data from spectrum analyzer but I came face to face with the problem that I explained in the link below. http://forums.ni.com/ni/board/message?board.id=170&thread.id=405775 If you can solve this problem by using that VI,I really appreciate it. Then another solution came to my mind. I defined the VIs inside the .llb file as an executable file. But, then I had trouble with the command line input of "System exec.VI". I either got error#267 or error#2 despite the fact that I have spelled the file path correctly any time that I run the code.(attachment 3650.VI) What should be the input to command line the System exec. VI? Should I write cmd.exe or the file path as an input to command line?(I am using Labview 8.2)
Thanks a lot
(3,609 Views)
Accepted by topic author deniz
Reply provided in other thread.
This thread should be closed.
(3,602 Views)
